Well, I have figured out my other wiring problems but have discovered a problem with the emergency engine kill switch which has been causing the motor to quit. This switch is the one with the little rubber boot that fits onto it that depresses a little button allowing the engine to run. It has three wires coming out of it. Inside is a little metal ball on top of a spring which is pushed down when running and disconnects the three wires. I cut the wires from the plug, which is faulty. Any idea which how the wires goe together to connect the circuit so that I can bypass the switch until my replacement comes in?
Try purchasing an owners manual, i found those very very very useful when i was working on my old sled, it would be 30-40$ well spent!!
two-stroke-smoke
Ol' Blizzards are sweet sleds. My dads last racing sled. Good luck getting it fixed!
Owner's manuals typically don't contain wiring diagrams. :(
