OK, I got a 1995 Polaris Xlt Special, 600 Triple. Im haveing trouble with all the lights in general, they all seem to work, but they all are getting minimal power, ie, they are very dim. im thinking its a fuse or something, but i really know nothing about sleds, any help? costs to fix would be great too, if its a simple fix. thanks a bunch
SOUNDS LIKE YOU MAY HAVE A BAD GROUND OR CORRODED
CONNECTION SOME WHERE, CHECK GROUNDS A CONNECTIONS THE WILL PROBABLY CURE YOUR PROBLEM.
GOOD LUCK
I had the same problem on my 650.
it was the Voltage regulater.
does the light get brighter as you give it gas?
If it does'nt then ya its a bad ground, check your wires coming out of the mag side, ive had a problem with the wires rubbing against the steering colum before I moved them. they were rubbing a wair in the wire coating.
yea if the light get way bright when you rev it, id look at the V.reg. i just thought by the way he wrote it that it was dim all the time
