I have a 02 SXViper and my lights are going dim then bright this is all of the lights not just the head lights and at an idle you can see a little flicker in the lights also when I switch from high beam to low the tac drops to zero then comes back up.So far ive tried changing the regulator and no change so then I went through ever connector made sure they were clean then put dilectric grease on them , also cleaned the ground.At idle im getting 11 volts and as soon as you come up off idle im getting 12 or a little better.Im pullin my hair out trying to figure this thing out so if any one has any kind of an idea of what to try next my ears are wide open.
Rick:dunno:
Rick:dunno:
