Hi im looking for blueprints for the starter ring 86t that are used for the grandtouring 583 -98.
Also blueprints for the mouting bracket for the starter engine same sled.
Icant find them new anywhere so i figured ill make some.
Blueprints? I doubt anyone would have those.
Blueprints ? Seriously ? More likely you might get someone who has one to sketch it out on paper. That would be as close to a blueprint you'd get.
Steve
These are the three parts...
417222858. Ring Gear
420853730. Starter Bracket, PTO (Main). this one does the alignment to the ring gear.
420953011. Starter Support, MAG. This one just supports the back of the starter, can be fabricated any way you want.
Now, getting the info to fabricate is tricky, but the ring gears are the same across all models from 1993 to 2004 (at least).
I see that you are in Sweden? So I'm not really sure what you have available to you, but I see them on ebay.com:
For the brackets, I don't have one for a 583, but I think the one off my 380 is the same thing. Problem is, I'm not sure what I did with that bracket when I removed it.
Thank u.
I know blueprints are not right but a sketch or pics and some messurmanets would do fine to,
My problem is that i dot have any of it so i cant look at them.
Thnx for the ebay tip didnt think about that.
