Electric starter doesn’t seem to be getting power. Not even a click. The sled will pull start and run so the kill switch and tether seem good. The start button is also working for reverse.
Is there a fuse I have missed? What else should I check?
2015 ski-doo renegade 600 sport carb.
If you can access the starter wires, test the voltage at the bigger wire that feeds the starter. If you do not have voltage when you turn the key, the solenoid may be bad. If you have voltage with the key, the starter may have bad brushes or a problem with the windings inside. That should guide you a bit toward where the problem is...
There is a 30 amp fuse. Not exactly sure where it is located, but shouldn't be hard to find.
