1 - 12 of 12 Posts
1983 Yamaha Excel III 340. I can’t get the electric start working. Brand new battery and universal solenoid, and I rebuilt the starter. Solenoid is clicking, and makes a humming noise. It is getting 12v at battery side of solenoid, and 4v at starter side. I switched the wires around and it does the same thing. I don’t know if I have something hooked up wrong or what. Any ideas? I don’t know much about electrical troubleshooting.
64955
Discussion Starter #2
Some more digging, I found that the starter spins when it is not attached to the motor, but when I put it on, nothing. Just the previously mentioned whining noise.
Welcome
You are not getting enough power to the starter
Is the solenoid grounded
Is the starter grounded
Connection clean and tight
If you put a jumper cable to the terminal to the starter will it start?
Try putting it to the small terminal and see
Discussion Starter #8
No. It doesn’t seem to be working at all now. I wonder if I just need a different starter? I don’t really want to spend anymore money until I know it’s the problem though.
Discussion Starter #9
I got it working. When spinning it by hand, I noticed a rough spot. I worked some WD-40 in it and got it spinning smoother, and cleaned the commutator, and it worked. It seems to be spinning the wrong way though. What would cause that?
Discussion Starter #10
So, I figured out it works properly and spins the motor if it is hooked up backwards (negative to terminal, positive to starter case). I changed the brush plate, I thought maybe it was backwards, but it only fits one way. Any ideas what would cause this?
1 - 12 of 12 Posts
