Due to my speedometer not working, Im looking to replace my drive shaft bearing on my 93 xcr 440. The only problem is last year changing the chaincase oil i snapped a bolt off in the chaincase. The manual says to remove the drive shaft. Is there anyway to replace that bearing without removing the driveshaft?
Also I replaced the cable because the old cable was stuck and wouldn't spin but it still does not work. However I have read that when the bearing fails the speedo cable key will shear off. Neither cable has had that problem in my case but I assume the bearing is still bad correct me if Im wrong.
Finally should I absolutely have to get that bolt out does anyone have any suggestions on how? Its a tight space so I do not anticipate it being easy.
