1979 yamaha 440 exciter the lights are dim put new voltage regulator on still dim not very bright. how do i fix this? what are possible causes, just bad ground or bad connections?
you have 2 out of 3 covered. the other would be low output from the lighting coil, unless you have a wire rubbed somewhere creating a short or cross feed.
Sled Of The Month Judge
I recently had this happen. My low beam popped and my bulb turned black. Try to replace the bulb. There is a rubber boot then a plug to take off, then pull off the plastic nut. the bulb should come out.
