Good point.
I've since learned that the issue is mostly around the reverse, that pretty much any gearcase will fit and are interchangeable between arctic cat sleds, but you may end up with a different gear ratio (or you may no longer have reverse). The 2010 CF6 still has a mechanical reverse, where most of the sleds in arctic cat's lineup changed to electronic reverse in 2009 or so, so an older gearcase from a 2008 M1000 will work for my needs, for example.
