hi i got a 1976 arctic cat pantera 5000 with a 500 spirit motor and the motor is flooded but i cant find the drain plug on the crankcase. any help with the location of the plug would really be appreciated. thanks
im not sure they have one but it should be under the exhaust manifold. if they dont then try taking out the vacuum fitting for the fuel pump to drain it
There should be one on the very bottom of the crank case. It would just look like a ordinary little screw. There should be one for each cylinder. I know for sure Yamaha has them and I'm sure they would all .
Yep, no drain plug on the suzuki spirit engines. You can take out the sparkplugs and pull like crazy. Thats what i've done to get the fuel out. Its worked for me every time, just a little messy thats all.
