i am attempting to assemble the crank and case halves, but I have the outerbearing (stator side) not wanting to fully seat into case so I can align the outer race guide pin. all other bearings i was able to allign the pins. anybody have any ideas. (1996 zrt 600).
Got home from work today and went straight to the garage, stood there for a minute thinking about what could be the issue with the mag bearing not lining up decided to remove crank and start from the mag side and BAM she went right in like i would have thought it should have last night from the other end. I got it all torqued down and decided to give you guys an up date and from your posts it looks like you allready knew.
And by the way no i did not have to replace any bearings, Thanks alot for all the input
