2009 crossfire 600.. Whats the correct way to shim my secondary clutch. If i add or remove shims on the front do i have to add or remove shims on the back between the clutch and ACT drive? Reason i ask is there is one shim between the clutch and ACT and two on the front.. So i want to make sure im not going to chew a belt trying to get it set correct..
thanks
JT
thanks
JT
