Could someone step out how to carry out a compression check?? I have the tooling, just wondering how to do it on a 2-stroke engine?? What should the compression be on a 96 680 Triple??
Thanks for the help.
jsut pull all plug wires, put the kill switch on and turn off the ignition, take out the plug you need to check. Then screw in the comp gauge hand tight, make sure the o ring is seated right, then jsut pull the rope untill the gauge stops going up, should be around the third pull.
