1991 400LC, 1994 XLT SKS, 2007 IQ 600 HO, 1991 340 sport, 1990 440 sport, 1999 XC 500, 1999 XC 700
I have a 1991 Polaris Indy sport 440 and I was out on the lake with a buddy and doing some doughnuts and riding around? and we switched sleds and not even 5 minutes in I hear a loud clunking and go rush over to my sled to see what's going on. I lift the hood and the primary is completely off with the bolt missing and the rubber plug to get to the bolt is gone also. The clutch also was locked fully closed and I could not open it. I got it home now but I don't know what to do. This comes from a long story where the clutch sat for 10+ years and was rusted so I got some sandpaper and cleaned it off and got it working good and worked for 200 plus miles great after. I have heard you can just clean the shaft (I'm assuming that's why it's stuck) or just somehow get a new one for cheep? All of the threads and all were still in tact and I put my clutch from my 1990 340 sport on there for now to get it home and worked good. I don't know how it came off because at the start of the season I cleaned that clutch and was working perfectly for 200+ miles and when I put it back on I torqued it to the 50ft pounds that are spec. Was maybe the clutch locking up part of the bolt also comming out or what's going on? Anything helps I don't know what to do or where to go but I'm also kinda on a budget so cheeper better but all options help.?
64859
Discussion Starter #2
got the time to look the the clutch and take it apart and saw the problem right away...
64868
Yep. That's a problem. ;)
It may be more cost effective to find a good used clutch for your sled than having that one rebuilt. When you are looking around for a clutch, be aware that the clutches from the triple engines of that era had a different offset and may not work on your engine. Try to find a clutch that came on a twin to be certain the offset is the same.
Yeah, that's that I decided too, hopefully looking at a sled this weekend.
