sorry, i guess i should have explained myself better.
the weights and spring should be swapped out and they are a direct bolt out/bolt in. in fact, there probably arent any bolts involved, just pins and washers.
the phazer weights are significantly different than the exciter ones. you will see that when you change them. alos note the spring colors for future reference.
