I have a 1973 arctic cat 440 and I'm having troubles taking out the drive shaft to install a different track. I have a parts sled I'm robbing the track off of and I can't figure it out. Should the bottom gear in the chain case come off? I can't seem to slip it off. Any tips????
When I did mine this summer I had a small gear puller I was able to get down in there, it pulled that gear off pretty easily. Not sure if I could have pulled the gear any other way, there are really hard to get off without the even pull a gear puller gives you.
