1 - 14 of 14 Posts
Hey im new here, I ride a 1996 Ski-doo Formula Sl, its a rotax 500 motor. But what i am wondering is how do i drain and refil my chaincase oil... it looks like i can just crack it open and let it drain becasue there is a hole underneath it. Could anyone tell me exaclty how to saftley drain the chaincase oil.
Discussion Starter · #2 ·
oh yeah and thanks in advance
King of the Universe
Many sleds have a drain plug on the inside of the case (under the tunnel?). Your idea of pulling the cover is not all that bad.....you can clean out he gunk, check gears, chain & tensioner while you're there!!:thumbsup:
Oh yeah!! You're welcome!!:thumbsup:
you just have to pull the cover and let it come out in the belly pan. it sucks, but thats the way they did it. once off like IRS said, check your chain over for broken links and your gears for wear and chips. adjust it properly, clean everything up really good and put it all beack together.
oh yea..... dont forget to fill it up with lube :cheeky4:
you mean chaincase oil..so lube=chaincase oil...cuz if i was dumb ide throw like chain lube in that *****...but im not....lol hey almost forgot....check my website
ENTER FORUM
Polaris Indy SKS 600 tripple - same question
Hi,
I have a '94 Polaris Indy 600 and I was going to change out the chaincase oil too, but no drain plug or any mention of how to do this in my owners manual (although it shows the location of the drain plug for the wide-track version of the sled). I thought I read a post were someone turned the sled on it's side to get the oil out. Anyone tried this? It seems crazy to me not to have a drain plug somewhere.
Kevin Woolard
I would think I would rather crack the seal on the case first. I watched them at the shop on my polaris 600 trip. they used s suction pump and a length of tube.
Gaskets/o-rings are cheap, plus you get the benefit of the cleaning and inspection. Better to find a potential problem in the shop than out in the middle of nothing.:D
there is an O-ring that seals it, i have NEVER had to change one from servicing. even when i raced watercross and had it apart five times a day every weekend it was still good. i would never suck it out and just re-fill, that is poor servicing and being lazy:thumbsdown:
Old thread. 2007. suck it out, remove the cover and let it drain, turn the machine on its side and drain out the fill hole. Do a chain case mod and put in a drain hole...
After changing the chain lube once, I decided to put a drain plug in the chain case cover. It wasn't all the way at the bottom, but I could use a turkey baster to suck out the last little bit.
1 - 14 of 14 Posts
