Maritimes Guy
I know its out there somewheres in the posts but I've tried and I could not find it.
I'd like to know standard settings for the air screw and also for idle screw and needle too. 1989 INDY 500.
Maritimes Guy
Discussion Starter #2
Forgot to mention, was working fine before I changed pistons/rings/crank seal pto side and clutch.
Hello, if you are talking about the jet settings for amount of fuel here is a thread when i was having problems with mine. The idle screw is really up to you once you get it running you just adjust to how high you want your idle to be. I think for mine i turned idle screw all the way out then went in about 3 turns.
http://www.snowmobileforum.com/polaris-snowmobiles/54359-help-polaris-gemini.html
