84 indy 600, I am getting gas coming out of the overflow tube. Took the carb apart and cleaned it and readjusted the float and still fuel is over flowing.
Could this be a sign of my floats being bad?
Poppy59,
If the floats are adjusted right and the needle is OK I would say check to see if the needle is sealing to the seat and make sure that there isn't anything down in the hole on the seat. Also check the gaskets where they seal the passages from where the gas line hooksup through the carburator. Hope this helps.
