i am pulling my hair out trying to trace an injector oil leak on my 98 mxz 670. the oil is collecting in the aluminum tray just above the front right engine mount. (if you're standing in front of sled) it's not alot but enough to notice, in about 10 hours there was enough to show a dime size drip on the floor. i recently changed the RV seals so they are new. i installed a new elbow fitting and clamps where the oil line goes into the crank case. i took the rotary cover off and filled the case with oil thru that line and filled the line and let it sit for 2 days and no leaks. put it all back together, fired it up for about 10 minutes and put it away. within 10 hours is when i noticed the oil as described above. i'm clueless and frustrated, where else could injector oil be leaking from to pool in the front??
