Hi, I just bought my first skidoo (1991 artic cat jag 340) and have a problem, I cannot get any spark, i have changed the coil and power pack. The one time i did get it going the headlights were very dim. Any suggestions?
I'm assuming the "power pack" you refer to is the CDI...?
If you've done the secondary coil and the CDI - "there ain't much left" other than the primary coil and/or stator. If lights were dim, sounds like you should be looking at the stator. Don't know if the light coil and primary ignition coil are separate on that model.
Well, it depends on the configuration.
http://www.brownsleisureworld.com/P...ld and test the new coil I just put in). ;)
