1 - 17 of 17 Posts
i have a 1976 arctic cat jag 3000, i have a hard time startting it
when i get done my chest muscle and left arm hurts
any way i can start it without hurting myself
after about 20 times pulling the recoil it starts
when i'm done feels like i'm having a heart attack
my left bicep in pain
Maybe get your carb(s) serviced and ensure your choke is operating properly? I'm not familiar with the older Cats, but this may be a place to start.
Best of Luck!
well ditch, my carb is still clean the choke seems fine
when i started it up i had the choke on half i use to have it
full when i started
well full choke it again
sled, i had the choke open this morning still took
a long time to start.. wish i had the money for a newer
sled can't complane when i got it for free
I would suggest that you start with the simplest test.That is check your compression.If it is to low your pump wont bring up enough gas thus needing lots of pulls to have enough gas to start your sled.You should have 120 to 130lbs for a good compression.Also try taking out your plugs and pouring in a couple tablespoons of gas in each and then see if it fires up .If it does then you know that you have a gas problem Good luck Dan
Discussion Starter · #10 ·
cat, the compression on both sides are 150 each
i checked for spark inside my garage with out the lights
it was cool looking. so i knew i was fine there.
Check all of your fuel lines. Sometimes hairline cracks in the fuel line will inhibit the fuel from flowing. Sort of the same principle as drinking through a straw with a hole in it.
I'm guessing its not your problem, but you have to start somewhere.
Discussion Starter · #12 ·
ditch i checked doubled checked the lines they were fine
my neighbor did the same. he use to have a jag like mine
i knew what he was looking for
OK so your compression is good.Try putting gas in the jugs before cranking it and see if it start right away!If it does then your sure its a fuel problem.Also you said you check the lines ?Did you check your pulse line ?You might want to take your fuel pump apart also and put in a kit .Very inepensive and should be done every 3 to 4 years anyways.Good luck Dan
Right on
Catlover is right on. If you make every thing mentioned is right it should always start by the third pull. One more thing- always add 1/2oz. of isoprople per gal. gas. One drop of water can plug a jet.
It comes from the motor crankcase. Typically beneath one of the carburators (on multi carb motors). It runs from the motor crankcase to the fuel pump.
Trace the hoses from the fuel pump. There is one supply line (to tank). One line per carb (duh). One impulse line. That line runs direct to the motor.
It uses crankcase pressure to actuate the fuel pump diafram.
However, it is my opinion that if the impulse line is at fault, the engine would run way lean, and you would be looking for advice on rebuilding your top end, instead of just a sore arm.
Does it start, or want to start, any different with a brand new set of plugs?
Try this test to elminate a rich condition. Pull the plugs out before you go to bed, or work or school or whatever. Leave it sit for 8 to 12 hours with the plugs out. This will allow any excess fuel to evaperate for the combustion chamber and crank case.
Install a BRAND NEW set of plugs.
Attempt to start the engine WITHOUT the choke. Half a dozen pulls or so should do.
If it doesn't start or fire, try 1/2 choke. Give it another 1/2 dozen pulls.
Try this after you try the teaspoon of fuel down the spark plug holes.
Discussion Starter · #17 ·
crush, plugs are brand new, i'll have my neighbor help me with it
he use to own a jag like mine many years ago i'll print this
so he can look at it. or as jack wade from james bond goldeneye
hand me a sledge will ya jimbo. my neighbor said there
were no cracks
1 - 17 of 17 Posts
