My snowmobile is low on brake fluid and I was wondering if I should just refill it or flush the old stuff out and then bleed the brakes.
Welcome
The reason your fluid is low So are your pads I would drain flush and replace the pads and fluid!
Defiantly flush the old fluid out! Normal maintenance, that very few seem to do, is to flush it out every two years. The fluid absorbs moisture and goes from clear to dark brown. As KC said, also check those pads.
