97 ski doo 380 touring e. Got started but as i run then slow down for something, sled bogs down. Can give a few primes when it bogs down and im back to running good. Any ideas
I had a 95 Formula S 380. It was a great runner. I would check the carbs first. Take them off and clean them. Pretty easy to do on that machine. Next I would look at the fuel lines. It's pretty old now and if there are any air bubbles in the line look for a air leak somewhere at a fitting or even in the tank (just fixed my 80 340 7500 Plus line in the tank a week ago as it had fallen off). Just check the simple stuff first.
Steve
Make sure the pulse line from the crank case to the fuel pump is secure and tight. I've seen several of the 380's that didn't have a clamp on that hose and it works itself loose.
But Cleaning the carbs is a good idea. I'd probably do the same with the fuel pump. Clean/rebuild
