could have clogged main jets in the carb!! low compression bad jack shaft bearings clutch issues!!! give more details how does it start how does it run through the low and mid range!! does it feel like your driving with the brakes on
it seems to bog down when i get on it. it will make a sputtering sound sometimes. but seems to ride good when starting out. then when i get it going faster it bogs right down. then it starts to sputter.....
Black plugs indicate too much fuel or poor ignition. try a new set of plugs, if problem is still there check compression, clean carbs and fuel filter, check electrical connections, check pipe for brockages, ect.
