Hey everyone, first things first...I know nothing about snowmobiles. I was given a 1997 polaris iny 440 xtra10. It needed a new belt put on it which I also received. I verified it was the right belt. How do I get it on? LOL I have tried turning the belt on with sled raised and belt seems to small. The cluth has 3 bolts with a cam that turns. All videos I find show a tool to use, but there is no hole 4 it. Please help!!
IF it is a Polaris belt it should be a 3211042 or 3211070 as they are the same belt. And yes it will seem like it is too small to be put on.
The way I do it is I have the back end of the sled off the ground so you can turn the secondary clutch by hand. Then I put it on the primary clutch first then I put it on top of the secondary clutch it will look like it won't fit as the bottom part will not be on, while I am holding it on top I have someone else turn the secondary clutch by hand in reverse and it then pops right on.
IF you have just gotten this I would recommend doing a lot of preseason maintenance as well. And getting a spare belt for it as belts can shred while out on the trail. If none of the preseason maintenance has been done let us know and we can make up a list of stuff for you to go through!
I have a '98 Indy 440 L/C with the xtra-10 and can help you with w/e you need for it including clutching upgrades that make a world of difference with that engine.
Welcome and enjoy your new toy!
Thanks coolhand. Gonna give it a try. I did get a spare belt with it and I would really appreciate if you could provide me with a preseason checklist. I am trying to study up so I can get to know more about snowmobiles. Thank you again for your help.
Yesterday I got my Michigan snowmobile magazine and they had a good preseason check list
If your old belt is not worth saving cut about a 3" piece of it, push it in between the clutches into the driven,
if you have a belt on you can pull up on the belt and push the piece in farther, opening the driven
Leave the piece in and replace the belt
Thank you all for your help and comments. Sure wish I could return the favors. Hopefully sometime and somehow I can. This forum is GREAT! The people, the help. Thank you all again.
Discussion Starter #7
Just to admit my fault...lol. I had said earlier the belts were correct when I checked. Thank you coolhand for those part #'s, I checked again and the belt is for a ski-doo and @ 3.5 inches smaller around. Wow, that will make a difference trying to put it on. I ordered the correct one, be here in a couple days. Thank you all again for your help and comments. I really appreciate it.
