I am needing to replace the axle on my trailer. I used this trailer to get a load of firewood last year and to make a long story short, bad things happened and I'm pretty sure I bent one spindle on this adventure. (Realized this after getting a load of firewood this year.) One side was really cambered in without weight on it. Not really doing a lot of thinking, I flipped the axle over and it was fine for last year's riding season. After getting my first load of wood this year, same thing, really cambered in on one side, and a little on the other without weight. (I don't remember which side was cambered last year.) I know some axles have a slight bend to them so they have a camber out and when there's weight added, they straighten out. To me it's a more extreme camber in than it should be. I'm wanting to replace it with a heavier axle so I can actually use it as a multipurpose trailer and because I'm a little nervous about using it this upcoming sledding season. We've got four wheelers, sleds, and I'd like to use it as a wood and garbage trailer. I'm not sure what weight rating the axle is under it now but I'd like to go with a 3500 lbs axle just to give myself a little cushion. My wife has a 94 Indy XLT and I now have an 08 summit. I know what the XLT weighs and I'm guessing the summit is probably a little under or close to that. The four wheelers weigh under 400 lbs and usually only 2 of them. I've had the XLT, my RMK, and an Indy Lite on this trailer before but that was only twice. This is a custom built ride on ride off tilt bed trailer. Seems very solidly built. It's 17 ft long. It has a straight axle under now. I'm wondering if I should just stay with a straight axle or if possibly going with a torsion axle would be a better idea. Also wondering if I should go with a lighter axle and just stop putting heavy crap on it. Thanks for your input and sorry about the long post
