Disconnect the key and kill switches and try that first, one may be broken. If that doesn't fix it, there's an exciter coil under the flywheel on the engine. That's probably bad.
well i had the same problem last year and i took the fly wheel off the stator plate out and realised that a screw in the back was loose and touching the stator plate and grounding out make sure everything back there is tight and not touching anything
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
