i have a 85 artic cat cougar that runs great for 10 mins and just dies. i spray gas in the carbs to get it going again and back to the house. changed filter and lines.IM STUMPED,PLEASE HELP!:confused:
sounds like yor sucking air from somewhere. Carb silencer is junk or your compression is low. Check the compression once it's heated up.
Remove the fuel line at the carb and see if it pulses out fuel when you pull it over. It should shoot pretty far. If not, you need a fuel pump rebuild (quick and easy).
