1 - 12 of 12 Posts
i have a 1976 arctic cat jag 3000,i'm not sure if the cold weather has an
effect or not. i tryed since friday up to
today trying to start my cat i have new plugs in it fresh gas but nothing
pull your plugs and pour a little(a couple dribbles) gas into the cylinders put the plugs back in and try it . if it fires up but wont stay running try spraying gas into the carb if it fires up but still wont stay running you most likely have a fuel delivery problem. either plugged up carb or fuel line or defective pump or pulse line
arctic cat won't run
i poured gas where the plugs goes, nothing i have my neighbors
carb spray i'll try that
Won't go
UNLESS. Check the filter and as much as I hate to say it, you might try taking the gas line apart b4 the filter and sucking gas out of the tank. Then reconnect to the filter.
1 - 12 of 12 Posts
