I just loaded my Daughters 99 Z370 on the trailer. I didnt give it enough gas so it didnt make it all the way up on. About 6 inches of the track was touching the ground. I gave it gas again but the track wouldnt spin and I could smell the clutch. I had to pull it off the trailer and this time give it enough gas to make all the way up. Was it common for this to happen. I was loading off of grass so the track probably wouldnt of spun as easy as if it was snow. Could there be a problem?? Thanks Locky!!
You may have flat sided the belt if you smelled alot of rubber when the sled was stuck, If you feel a rythmic thumping in the floorboards on the clutch side, that is what happened and you will need to turn that belt into a spare, maybe it is ok
