I lent my sled to my son a couple of years ago and he returned it with the skis worn right thru and the clutch jammed up so it will not disengage. I replaced the skis and I need some advice on what to do with the clutch. It's still on the machine and I've done some reading on using a clutch puller assuming I'll have to take it off. Are there some teflon slides or something inside that's likely been overheated that I can repair/replace that might be causing it to not disengage? I'm hoping I can fix it without having to buy a new one. Sled is a 79
