I pulled the cables out of my air temp sensor somehow. I drilled it out and soldered it back together and that worked for a while but then it came out again. I drilled it out again and re-soldered it then put some glue on top so it wouldn't come out again but this time it didn't work. When I say didn't work I mean my check engine light is back on and it idles very low and sometimes stalls out at a dead stop. This is also preventing me from getting it in reverse.
So my question is this. Where can I get another air temp sensor cheap? Or is there an aftermarket intake that will come with one or eliminate it all together?
I've been looking on eBay and can't find the sensor or the entire intake boost box.
Let me know your thoughts.
Pic attached so you can all see what I'm looking at.
