Air silencer, is that the same as silencer. In that case YES it's very important. The pipe will reflect unignited fuel back in to the cylinder(s) and wether that should work there must be a precise resistans in the pipe, if you remove the silencer it will not work properly and it will sound terrible. The exhaust system is one of the most important things in a two stroke engine.
