hey folks I been thinking about getting a set of aftermarket reeds for my 2015 xf 8000 just wondering if they are really worth the money? If so which are the better ones boyesen or vforce?
Discussion Starter #2
I have a can on the sled and a speedwerx clutch kit going on it, might be changing the pipe and y as well
I've used both and both are good products. I have also replaced stock reed petals with the Boyesen replacement reeds in the stock holders, and they worked well, as well.
I was wondering if you could just change out the pedals or if I had to buy the whole new cage as well
Usually you can just change out petals. But if you do their matching cage you get a little bit more performance out of it. Either way it is an upgrade over OEM for sure.
