So, i put heavy duty springs in my zl, and now the rear 2 bolts that go into the tunnel arent lining up at all, anybody know what to check for ? thanks in advance...
You will have to use a rachet type strap and wrap it around the upper shaft of the rear sissors arm so it can compress it enough to line up the torque arms to the tunnel.
I'll third that, works great.
I also have heard of using your track adjuster (tension adjuster). Tighten the track screws and the arm will drop and things will start to fall into place.
