alright i was riding out in the fields the other day and my sled stalls, i checked for spark and there was nothing at all. so i tested my coil that was fine, so i put on another cdi box i had, and still no spark. any suggestions at all would be great. thanx guy
Alright first thing to do
BYPASS YOUR IGNITION! North and I just had a hell of a time with our sleds doing the same thing. Take the two wires off your ignition, SHould be a brown striped and black, if they are the same, and jump them together. Then check if you have spark, then you have a bad ignition.
If that doesn't work, tackle the throttle overide.
Hope this helps
