I just got a 98 zr 500 and the previous owner says it's got a clutch kit in it but was done by a previous owner before he got it.
honestly it rocks for slow trail 0-60mph but i feel over rev's badly past 60mph.
it will spike at 9000rpm and hard fuel will do a constant 8500rpm
the weights say 46.5 on them on the primary and the spring is yellow . the secondary is yellow spring as well and is in the center hole for tension. i can get pic later if required.
I want to play with it as I'm not overly happy with it top end power or speed.
just want to get some feed back on peoples set ups that work better then this.
machine is stock pipes. and has studded track.
