Hello. I have searched as a noob should with no avail! I own a 1998 XC 600 with a little over 600 miles on it. The sled runs, rides and drives perfect! However when the temps go below 15f I can pull and pull with no start. 15-30 pulls and nothing. It does sit outside in the elements. This sled is like new! Now when I put it in a heated area she starts right up after 30 min or so on the second pull. Recently it was in the back yard and I could not get it to a heated area, so I put a propaine torpedo heater above the engine bay and blew the heat at the top of the engine with the plugs out. After about 10 minutes she fired right up (there was no wind thank goodness)! When pulling in the temps below 15 I can see that the plugs are wet and a little black and wont fire at all. But those same wet plugs fire right up after a small amout of time with the engine exposed to heat. All help is much appreciated in advance! Thanks for the help.
Cheers, Rick
Cheers, Rick
