i cannot for the life of me get the flywheel off. i have used and broke steering wheel/pully puller, machined my own puller, (copied design from nappas puller, just beefer) and if i use a snipe to tighten it more, it just breaks the bolt... i have tried a bit of heat, spray lube (all kinds i know of) i have let it sit for a night soaking (i tipped sled on the side and filled the little cavity with spray lube) im running out of ideas
. anyone know of a trick that works?
