Trying to sync these carbs using the documented procedure in the Polaris 96-99 Service manual.
This doesn't work, and I was just wondering if anyone else has tried this
It states to :
-back the idle screws out 'about 3 turns'
-insert the appropriately sized drill bit/gauge (7/64 for this carb/year) under the slide
-turn the throttle cable adjuster until there is a slight drag on the bit
Problem is that doing this, the 7/64 is way too small (it's more like 1/4)
Anyway, I've never used this documented polaris procedure. I've always just
equal and rose at the same time when the throttle was pressed.
(no snow here, bored, so I thought I'd check some stuff out
Has anyone tried this as documented in the Service manual?
Thx
It states to :
Thx
