my buddy was riding a trail with his little girl in front of him.she kept hitting the kill switch by accident so hed pull it up before it died to keep it going.he said she musta done it around 20 times in 10 minutes.then out of no where it stalled and he hasnt gotten it running since.he did a compression test and got 35 psi and 170 psi???so clearly he needs piston or rings for one side but has anyone had this happen to them before???any advice would help.thanks guys
I would do another compression check.. Make sure he does it right... If he had a bad seal or not done properly you might tear it down for no reason... What colour were the plugs running when it died?
do a spark test. i know when that kill switch gets used to much it will make the kill switch not work. if it doesnt get spark after the spark test unplug the kill switch and go from there. make sure you do the compression test right tho
