I have not done anything with the rail, assuming you mean fuel rail.Welcome
Have you removed the supply from rail (clutch side)
Just pulled the pump. There was only one filter. It goes straight down from the pump to a T. Then one side of the T is plugged and the other side has a hose 12-18" to a filter like I have seen in other posts. I assume the pump is not original and I'm not sure if the filter is. The filter is stamped Walbro and the pump is stamped Walbro AOUO90 10694-1 PAT NO 4500271. Do I just find a new smart valve pump and system complete or is it worth rigging it up. Do I really need this "smart valve" setup?Right
Thats what leads me to believe it is the regulator.
But clamping off the return should have increased the fuel pressure.
You may need a pump?
I replaced mine with one from Auto Zone
They were able to match up the numbers and had one in stock!
Picked up a use pump and full smart-valve system from a running sled. Finally had the time to put it all back together and it runs like a top!Does the pump work?
I believe if you take the pump itself in they can match it
Put it all back With the smart valve
