Lately I have had a few problems with this sled, so I'm not surprised...
A few weeks ago the reverse quit working then the drive chain broke. I replaced the chain and idler gear with new components and it ran great for a while. Now I can't get it to stay in forward drive. I'll put it in forward drive and drive for about 30 seconds and it will pop out into neutral. Then start the entire process over again.
I have not had a chance to pop the cover off to see what is happening, but thought I would check here first for some ideas. Could the linkage just be out of adjustment? The bottom gears still looked good.
Any ideas?
Could be a linkage problem but if you already had problems with it you may need to change the buttons between the forward and reverse gear. They get rounded off on the ends when you go between gears without completely stopping. That will make it jump out of gear, if you hammer it even mor so.
