Rocky Mountain POW!
I'm trying to replace the head gasket(orings) on my sled and I am wondering what is the easiest way to drain coolant from the sled. The manual says there are a couple of screws you can unscrew to bleed air out, but it doesn't mention how to drain and refill? anyone know a quick and easy way to do this? Appreciate the help.
I use a small shop vac and undo the top radiator hose and suck all the coolant I can get out. You can remove the lower hose, but it makes a really big mess, the coolant doesn't find just ONE place to drop out of the pan, it pretty much runs out everywhere. Hard to catch that way! There are no drains in the system.
