I bought a 96 Vmax 600 DX last spring and just noticed a problem with the steering rod, or tie rod end. It is not coming thru the hole meant for it, it is accually about an inch higher, so it has rubbed a notch for its new location. Can anyone tell me the reason for this? Is the tierod supposed to be attached to the ski arm on the bottom? Has the ski/shock slid upwards in its mount? or worse case, the frame that the ski mounts to is bent upwards? I am hopefully attaching a picture of this. Thanks in advance.
