1 - 1 of 1 Posts
I started to prep my sled for studs and this is what I have done already:
I put a shield over the heat exchanger crossover hose on the back.
I took off the stock tunnel protectors and added 3/4" ones.
Following this I reinstalled the rear suspension (which I had off to replace a shock & hy-fax).
After re-installing the suspension I noticed that the top of the track is resting on the new tunnel protectors. I do not see any way off adjusting this.
Does anyone have any info regarding putting studs in my sled? Are there any restrictions? Any other things that have to be done?
Any help would be appreciated, its starting to get cold again!!!
Thanks,
1 - 1 of 1 Posts
