Hey everyone! First post here,
I have a 96 xcr 440 sp (red head).
I got it off a family member and it was sitting for 2-3 years..
put new
-gas line
-fuel filter
-spark plugs (bR9es)
-plug w
Also flushed the gas tank and cleaned the carbs.
carb air screw is 1 turn out
everything seemed fairly clean for tiring that long!!
It fired up good and seemed to run ok! Took it out down the road and there always a bog until about half throttle then she picked up and went.. I thought maybe i just needs a run.. so about 3 days go by and I take it out a few times to try and work the bog out but no luck.. so I started checking things and couldn't see anything that would point me to the bog..
so trial and error I started to go though different parts.. taking them off my good running sled..
I changed
Primary clutch
Fuel pump
Carbs
Belt
Exhaust
Coil
Choke cables..
the compression is 120psi in both
I'm honestly at a loss for what to try next.. anyone maybe point me in a direction I'm missing...
put new
-gas line
-fuel filter
-plug w
I changed
Primary clutch
Fuel pump
Carbs
Belt
Exhaust
Coil
Choke cables..
