Hello everyone, just bought this 96 phazer off a kid that needed the cash, it's in kinda rough shape but thought it would be fun to play in the yard with, the kid told me the right carb had a sticky needle valve but said it ran good once it warmed up, as soon as i got it i fired it up and found that it was only running on one cylinder unless you feathered the throttle some then the second one would kick in.. i checked the plugs after running it awhile and found the left one looked great and the right one was wet and dark.. this morning i pulled the carbs off, took them apart to clean them but they both actually looked pretty good, one was missing a rubber plug that i replaced, put them back on and fired it up and it seemed pretty good, still had to feather throttle a little to get it going, but just a little, ran much better.. so i run to town and get more gas, fill it up, now it runs like crap, wont run at all with choke off. the line running from the fuel pump to the engine block is full of gas, took it off and turned the motor over until no more gas was spitting out of the block, does this mean the fuel pump is junk? or should i still be looking at the carbs? sorry for the lengthy post but wanted all the info there, any help would be greatly appreciated...
