Hey all, I just bought a 340 ovation and the sled is in mint shape. I bought it about a month ago so I am still getting to kno it. The problem I am having is when you start the sled up cold it runs fine but after about a half hour of riding it and I pullover at an idle it will bog right down and die. It will take about twenty minutes to get it going again, I check the plugs and would think it would be flooded but it never is. Once it dies all I have to do is just keep pulling and pulling and it will eventually go and when it does it runs fine until after another ride it will die at idle. I've tried changing the plugs but it never makes a difference.
Any help is greatly appreciated. Thanks
i would check the stator output as well as cleaning the magneto's flywheel and look for any bad wires coming from the mag. sometimes a corroded flywheel can act like that but it sounds more like a bad wire in the stator thats breaking down from the heat.
